massahwahl
Could I name the shortcuts though? Like title the movies?
An 8800 for a HTPC is so far overkill it's borderline idiotic. (If you're on a budget anyway)
What would you recommended and why?
Alright, I just thought it might be easier to run it from linux strictly as a media center setup so there would not be any need for some of the confusing linux problems. In any case, we'll stick with vista.
I was under the impression that you could buy GPU's with HDMI outs. Is that not correct?
From 44.99 to 509.99
http://www.newegg.com/Product/Produ...&Subcategory=48&description=&Ntk=&srchInDesc=
Some have HDMI some come with adapters. I don't think you'll see a difference in a DVI adapted to HDMI.
Dude, you can buy a DVI to HDMI adapter for $7.99.
WTF does that have to do with my post?
He wanted a video card with HDMI, some have it, some have adapters. There's no way to sort them.
Should I scour the net for more???
This is just newegg, and there's more there.
