i had some of the settings on very high screwing around. IMO anything above 25fps seems smooth. I found the other day that GTA SA caps at 25 fps
anyway, im going to install some patches and when my ram gets here, it should be sweet![]()
one thing i dont get, is why 30FPS is so smooth? i sure as hell know you cant play COD4 or most games on 30fps and it be smooth?.. i saw some other people talking about that.
Maybe its just the game engine, i like it
Most people are saying how they hate the crysis gameplay, i think its great.
But i still can't get past the stupid chopper!!!?? any suggestions? lol
are you in XP still?
I just compared DX9 and DX10 in a few difference places. DX10 is ALOT better, alot of features are not available in DX9.
I think you're still supposed to get the light outline in xp though.. Do you got all the setting cranked as high as they can go? No I wouldn't think so, try putting the shaders, post processing or particles on very high, that might do it. If not, try the other settings..
Hit the "~" key while playing. Type "con_restricted 0", hit enter. Type "r_sunshafts 1", hit enter. That will give you the light rays regardless if it's being run in DX9 or DX10.
I've got everything on High, not very High... Think it'd make a difference?
It should have them anyway shouldjn't it?
High is dx9 and very high is a DX10 setting. I think. Doesn't the Dx10 on XP simply unlock the very high? Just try setting one to very high, then the next, etc.
