Its a higher resoloution display, 1920x1200 vs 1680x1050, means clearer, sharper display. Basically,its higher res than "high definition" 1080p.Do i really need the matex finish?
Sometimes they come before they say they will, just depends on the workload.Nvm, alright i paid for it though its going to get here after i leave![]()
bomber, for around 1500-2000($) overall, do you think this is one the best overall deals you will find?graphics card is mint. is this a trusted company?Tbh id look at sager, can get a GTX280M graphics card vs the 260M:
http://www.sagernotebook.com/product_customed.php?pid=129131&action=customize
Yes, in my opinion, other than the panasonic toughbooks(not for gaming though, just rugged as heck and nearly indestructable), they are the best notebooks made.bomber, for around 1500-2000($) overall, do you think this is one the best overall deals you will find?graphics card is mint. is this a trusted company?
whoops i meant this one i think. this seems very very decent for its price(?) i dont really want high powered games, just like cs and cs source etc and games with requirments similar to those. do you think i should seriously consider this?Then, a GTX260M based notebook would be better. This is a 15.4" notebook here:
http://www.sagernotebook.com/product_customed.php?pid=160092&action=customizeCustomize it with the following:
Display: 15.4" WUXGA LCD with Matte Finish Surface (1920X1200)
Processor: 45nm Intel® Core™ 2 Duo Processor T9600 / 6MB L2 Cache, 2.80GHz, 1066MHz FSB
Memory:4GB Dual Channel DDR3 SDRAM at 1066MHz - 2 X 2GB
Hard Drive: 320GB 7200rpm SATA 300 Hard Drive
With those total would be $1894.00
Yes, that is a sager and as i said before, sagers are among the best notebooks made.whoops i meant this one i think. this seems very very decent for its price(?) i dont really want high powered games, just like cs and cs source etc and games with requirments similar to those. do you think i should seriously consider this?
this is in us$ right aswell?
would the video card be good enough to support more high powered games?Yes, that is a sager and as i said before, sagers are among the best notebooks made.
You could prolly play crysis at mediumish/medium high settings.The GTX280M is basically a desktop 9800gtxwould the video card be good enough to support more high powered games?
