bomberboysk
At that price point...there are two brands worth buying, Windy Soldam and Mountain Mods. Lian-li isnt that great once you hit the expensive cases.
Nah, too lazy to pull everything apart so i can get the grinder out...May put a rad on there to cover it anyhow.You still haven't fixed that weaponry on the back huh?![]()
Specs? I love that gigabyte board....what cpu you got in it? Phenom II X3 or X4?Been building a new main rig, just need to install the GTX260 (when it finishes the WU it's working on) and do a little cable management.
Neither! Got a 550 BE unlocked to quad-core running at 3.8 stable!Specs? what cpu you got in it? Phenom II X3 or X4?![]()
i'll probably get one of these eventually:
Noice!Neither! Got a 550 BE unlocked to quad-core running at 3.8 stable!
4GB Corsair DDR3 1600mhz
2x 500GB HDD in raid0
PC Power + Cooling 610W
CM Storm Scout
And the 260 which I'll be putting in at some time today.
I need to get this one running, as the weather is heating up here and my Lian Li case can't keep things cool without some modding (which I'll be doing as soon as I get a dremel)
I've got another Lian Li case all ready for liquid cooling, just keep finding other stuff I need moreNoice!
Throw some water into the mix![]()
	well done Buzz. Looks hella clean. You runnin SMP with that proc yet?![]()
Looking good! I'm sorry about what happened. is that the exact case you where going to sell me?
I ended up having to lug the box with the case in it across 4 different trains. serves me right i guess!
On another note, I squished cables under the HDD with the HDD for better airflow. It worked.
I'm thinking of extending the CPU power connector, because i can't route mine through the other side of the case behind the motherboard tray. it's too short. Is this safe?![]()
Nah, I got one for myself, it's a great case to work in!
I've changed the colour scheme to green, looks very cool! I just need a new front fan, the only 140mm I've got is orange!
I've got a comp with the CPU cable running up the mobo like yours, been good for about a year, would drive me nuts if I had to look at it through the window, tho!
