Joshua1187
are you running the 5970 at stock clocks?
That is correct sir, the new 5970 i just got.
hey, another eyefinity userwe should start a club
do you have any links supporting that claim though?
Well, this was from June, and as it turns out Nvidia accidentally enabled phys X while and ATI card is present, you need the 257.15 Beta drivers for it to work, so if you can find those drivers it would work. Here is the article. http://www.tweaktown.com/articles/3344/ati_radeon_hd_5870_5970_with_nvidia_physx/index.html
I had thought they added it for good, my mistake.
Also eyefinity is when you use more than on monitor using the 58xxx series. It's just what ATI called it.
nothing i play is on the list, thanks for saving me the money...
what if I just rolled with a 5870 as my main GPU for windowed mode CFd with the 5970 for Full Mode, would this make a huge difference in high performance?
Well I,ve atempted that with the last 5970 with Joh,s help but I was thinking would CF help me hit FFXIVs graphic potential much easier or do you think OCing to 5870 clock will be enough?
so you think OCing my 5970 will be the same as trifiring a 5970 and a 5870? My response to the i7 is, instead of paying 2k or whatever, ill stick with the performance i have XD. Not tonight, but I think somtime this week i will attempt once more to OC my card, it just makes me nervous messing with a $600 anything, ha. I'll let you know how it works out![]()
BTW, does overclocking the 5970 OC both cards? im assuming it does.
Don't have time to re-read 14 pages, but what resolution you playing at Joshua? The snowboard sounds like a good plan![]()
