Post A Pic Of Your Pc Here :)
where do i list it and how ? my graphics card is nvidia 9800gt geforce im pretty sure that doesn't have 2 ports
Just list it out for me here, I'm not sure if you can have a signature yet check in your user CP.
9800gt should have two DVI ports though, even if it doesn't it will atleast have a VGA port for a second and you can just run a VGA instead of a DVI it'll work fine for a second monitor.
hi buddy my spec is up know ok so i can connect to monitors your saying ill have a looking cant i have both hdmi or dvi ?
Heres a pic of my rig since i upgraded,Appoligies for the crap blury photo...its the best my Samsung Tocco phone can do :/,Really need to get a real camera!
Are those the loon fans you bought that you have on your Megahalems in the picture? If you wow they are thin. Hows the airflow, it looks like you have it done in a push pull setup? Do you have a part number for those.... they look really good :)
Pics of new rig coming soon to a thread near you...
Probably won't be too spectacular, but at least I have some LEDs.. :D
The side panel is usually on, it was off to take this picture though:
this thing is a bloody monster, that is 10.5" of video card there with my GTX260, and look at the amount of room left :eek:
They are yes,Perfect size...if they had been any thicker it would hit the top of my ram so i had to go with these 120x120x20mm instead of 120x120x25mm :P
I got them on Ebay quite cheap
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=230568224586&ssPageName=STRK:MEWNX:IT
The airflow on them isnt anything to brag about at 41CFM,But for the price they actually perform quite well in this push/pull,my idle is around 29c and load not over 70c.
Shame this Megahalems cooler even in push/pull still cannot beat my Tuniq Tower 120 Extreme i had back on LGA 775. :/,But thats with an entire diffrent Cpu/Architecture so...
lol mine is never off, was just to show you the inside :P
You should turn the cooler the other way round and do Push/Pull too ;)
Very nice system though,That a 5770 or something?
Not sure on the mobo colour :P
With my system,I think i found out why it performs like crap when i have the GTX 460 + 8800GT as dedicated Physx.....been a dumbass ive only just found out that my mobo is only Crossfire,So even though im not doing SLI it probably does not like there been two Nvidia cards in there at the same time. :/
aastii you run a gtx260 just for physX? Bit overkill/power demanding just for that. I'd get a gt430 or gts450 at the most.
wait i thought you couldnt run a nvidea dedicated card with an ATi card? I guess im wrong on that one. I thought that physX would shut down when it saw an ATi card installed?
Hmmm im gonna have to check, and see what my fan is now. My Xigmatek Black Knight is keeping me at 26 idle and 51 load with the current overclock, im not going to complain. I jus tthink i might run into the same problem you did if i turn my cooler . right now its facing the same way that Aastii's is... evedently i need a different mounting bracket that im ordering next week to change its direction but worried about not being able to access that 4th memory slot
I cant use the first slot either,Dont you just hate where they put the memory on boards these days when they know most decent coolers are on the big ish sizde :P
yeah most decent coolers these days are pretty big, hmm we should start writing companies and complaining lol :D
