where do i list it and how ? my graphics card is nvidia 9800gt geforce im pretty sure that doesn't have 2 ports
Just list it out for me here, I'm not sure if you can have a signature yet check in your user CP.
9800gt should have two DVI ports though, even if it doesn't it will atleast have a VGA port for a second and you can just run a VGA instead of a DVI it'll work fine for a second monitor.
Heres a pic of my rig since i upgraded,Appoligies for the crap blury photo...its the best my Samsung Tocco phone can do :/,Really need to get a real camera!
hi buddy my spec is up know ok so i can connect to monitors your saying ill have a looking cant i have both hdmi or dvi ?
Are those the loon fans you bought that you have on your Megahalems in the picture? If you wow they are thin. Hows the airflow, it looks like you have it done in a push pull setup? Do you have a part number for those.... they look really good![]()
im begining to think everyone leaves the side panel of their case off lol
lol mine is never off, was just to show you the inside![]()
aastii you run a gtx260 just for physX? Bit overkill/power demanding just for that. I'd get a gt430 or gts450 at the most.
They are yes,Perfect size...if they had been any thicker it would hit the top of my ram so i had to go with these 120x120x20mm instead of 120x120x25mm
I got them on Ebay quite cheap
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=230568224586&ssPageName=STRK:MEWNX:IT
The airflow on them isnt anything to brag about at 41CFM,But for the price they actually perform quite well in this push/pull,my idle is around 29c and load not over 70c.
Shame this Megahalems cooler even in push/pull still cannot beat my Tuniq Tower 120 Extreme i had back on LGA 775. :/,But thats with an entire diffrent Cpu/Architecture so...
but worried about not being able to access that 4th memory slot
wait i thought you couldnt run a nvidea dedicated card with an ATi card? I guess im wrong on that one. I thought that physX would shut down when it saw an ATi card installed?
I cant use the first slot either,Dont you just hate where they put the memory on boards these days when they know most decent coolers are on the big ish sizde![]()
