Rocko
Not bad rocko :good:
haha thanks, but I dont know how much more I can push with this guy, its only a 945.
ive tried prime 10 times but it seems to freeze every time. any idea why? im running windows 7 32 bit ultimate
Are you sure you are stable? And no offense, but why are you running 32 bit with 8gb of ram? If your 32 bit machine isn't the one listed in your sig, then disregard this!
With a 32 bit machine, your computer will only use 3gb of 8gb you have installed.
meant x64 type o and yes very stable ATM, i took my meds today
and the machine is also
Sorry that took a while, I had two computers to fix
You take spot #9 mihir!![]()
do i win a prize?
I'll try again when i do some real OC'ing.
No, but you do get added to the scoreboard.
