funkysnair
very good sir
Updated
Come on Jevery, get crackin
You forgot mine mr bomber!.....HOW DARE YOU! :good:
I didn't forget any, if it's not submitted to the spreadsheet, it doesn't go towards the rankings. Thats made pretty clear in the first post
red X, link seems to take forever to load and I just closed the window.
Yeah I also had a 2500k, he just messed up it should say I5 not I7. But I was at 5.1ghz
I use MSI afterburner, great program.
Forget furmark, you should be able to run 900 core clock on stock voltage with no issues. Just doing that, and getting your CPU to ~4.6ghz you'll easily pass my score. Remember I was only on gts450's, pretty weak GPU's.
Yeah.
c:/program files x86/msi afterburner
Open up the CFG file with notepad. Scroll down to EnableUnofficialOverclocking, which is near the bottom, and change the 0 to a 1. File/save. Restart afterburner.
