|Official|Black Hole: Benchmark Ranking thread
I'll do it for you my friend :p
edit: I updated it to zip :D
thanks. Scores here.
Bigfella, I like the design style of the new graphs, and thanks for taking the time to do the other graph regarding the correlation between clockspeed and scores too. Much appreciated! :)
I see a new version has been released - I'll try it out! :)
Thanks man, i was going to try and make the same cpus the same colour, but then i cbf.
With this new version...
Boys why not just the display the score in the same metric as before? If you continue to change it, the whole things becomes meaningless ;)
I agree with you Bigfella - Smile wrote this one as I out pretty much all day yesterday. ;)
OK so here are my scores - i5 2500K oc'ed to 4.3GHz as per the usual. :D
One thing I did notice was when you run the Single-Threaded test it spreads the load out between each core, it is not maxing out one thread/core like it presumably should be doing. The Multi-Threaded bench maxed all cores out though.
As for name suggestions - Viper Bench, Fury Bench? Something like that?
Thats normal, every cpu spread his work over the cores.
But that doesn't matter in scores I noticed.
Bigfella, I'm working on a design which I gonna use almost forever if it's done.
The metric is just the same as the previous, only the design is a bit different.
I reduced all the information by putting it in a menu.
And I like it now more as before. But thanks for your suggestion.
ty, btw, nice benchmark table. But maybe let the score start at 4500 points or something so you can see the difference.
Also a nice idea to give the same color to the same cpu!
BS! The metric is not the same. Running for 9k is not the same thing as running for 300,000.
aah, I thought you were meaning the metric of the benchmark itself :p
I'll try to give it same results as before. But I fixed the score system from previous version, because if you had a too slow cpu, you had 0 points. Now thats fixed, but this is only the preview version. The v1.1 is still the official one.
You should check the code on Phenom II's. Mine keeps getting different results with no changes in my computer. It's been as low as 3000 and up to 5300. I did it twice this morning and got 49xx each time.
hmm, yeah. I asked someone already to test his phenom 955, but he doesn't respond. But I see the other phenom in the benchmark is doing well....
btw: I have upped my ram a bit and got 10 points more again :p
sorry guys for the metric again, I thought I fixed it but it's much more sensitive then I mentioned.
Here are my scores with the fixed version of the preview.
