I would recommend posting the leaderboard about 25% smaller![]()
I'll do it for you my friend
edit: I updated it to zip![]()
	thanks. Scores here.
Bigfella, I like the design style of the new graphs, and thanks for taking the time to do the other graph regarding the correlation between clockspeed and scores too. Much appreciated!
I see a new version has been released - I'll try it out!![]()
	I agree with you Bigfella - Smile wrote this one as I out pretty much all day yesterday.
OK so here are my scores - i5 2500K oc'ed to 4.3GHz as per the usual.
One thing I did notice was when you run the Single-Threaded test it spreads the load out between each core, it is not maxing out one thread/core like it presumably should be doing. The Multi-Threaded bench maxed all cores out though.
As for name suggestions - Viper Bench, Fury Bench? Something like that?
BS! The metric is not the same. Running for 9k is not the same thing as running for 300,000.The metric is just the same as the previous, only the design is a bit different.
I know its a preview. We are trying to help you make it better.
You should check the code on Phenom II's. Mine keeps getting different results with no changes in my computer. It's been as low as 3000 and up to 5300. I did it twice this morning and got 49xx each time.
