type regedit in the run box, when regedit is open go to the tab edit there go to search and type EnableUlps and hit f3 then it shows up.
change the 1 to 0 and restart the pc, but you can also disable it with msi afterburner, trixx, evga presion. but I like to do it to the register
Why does this need to be done? His cards were running fine in CrossFire.
The Blue Beast, I don't see how changing a registry key would remove bootmgr. If you have any flash drives or external hard drives plugged into USB ports make sure you remove them because your board might be trying to boot of that instead of your boot hard disk.
