Geoff
We are just curious.does it matter?
Does it matter?
Does it matter?
Thats not true.I feel you're going to root just so you can say you're rooted.
To be honest, its really none of your businessWe are just curious.
Well since you asked us for help, we are involved now.To be honest, its really none of your business
Oh, okay. i mostly just wanted to try out flash fire and a app that is a apphider that needs root. and sometimes i look up how to do things on my tablet and they all say [Root users only].............Well since you asked us for help, we are involved now.
Sounds like you have some neat ideas to play with, no need to lock threads though.Oh, okay. i mostly just wanted to try out flash fire and a app that is a apphider that needs root. and sometimes i look up how to do things on my tablet and they all say [Root users only].............
so, thats it. you can lock the thread if you want
Okay, i already have a tone off root apps i got from the play store! now all i want is to change the boot animation from stock to something cool!Sounds like you have some neat ideas to play with, no need to lock threads though.
Also make sure you get Titanium Backup, it's an essential tool when flashing ROMs. If you want to mess around with things, try out the app Tasker.Okay, i already have a tone off root apps i got from the play store! now all i want is to change the boot animation from stock to something cool!
OKay!Also make sure you get Titanium Backup, it's an essential tool when flashing ROMs. If you want to mess around with things, try out the app Tasker.
I dont know. i downloaded the right framework for my cpu, and booted to twrp and flashed it. no more boot. anyways, i have got it fixed and im working on getting my root back with that toolkit U gave me.....It's not that hard to flash Xposed. How do you keep doing this?
There are several versions of Xposed, one for Android 4.4, 5.0/5.1, and 6.0. For each of those 3 versions, you have 3 for 32 bit, 64 bit, and Intel CPUs. All you have to do is flash the correct one in TWRP, and you will be fine. As long as you downloaded the right one, you can't have a problem...I dont know. i downloaded the right framework for my cpu, and booted to twrp and flashed it. no more boot. anyways, i have got it fixed and im working on getting my root back with that toolkit U gave me.
Which phone do you have, and what OS is the ROM you're using?okay, the toolkit rooting was failing, so i used the toolkit to push the supersu to my nexus, than i just closed the program and unplugged my device and flashed it manually.
Ummm, i downloaded the framework from here (http://dl-xda.xposed.info/framework/sdk23/arm/) and i got the
xposed-v77-sdk23-arm.zip one. is this right? my cpu info app says my cpu is a "ARMv7" is this one right?
Nexus 7 wifi gen 2 and he's probably on stockWhich phone do you have, and what OS is the ROM you're using?
I'm on a Nexus 7 2nd gen, with a Google stock ROM 6.0.1.Which phone do you have, and what OS is the ROM you're using?
Install v85 SDK23.I'm on a Nexus 7 2nd gen, with a Google stock ROM 6.0.1.
it just says "sending boot..." and i waited for like 10 min and thats all.NO! Have you read anything that I have said in this thread?
If you want to go the way of flashing just the system image to see if that resolves it, you need to use the Android ADB found within the Android SDK Tools. (skip the optional part - you'd wind up breaking something).
Download and install them somewhere (make life easy and install it to C:\Nexus7\ )and run the installed application when finished. Once the command window opens, boot your tablet into FastBoot mode (hold down power + volume down) and plug it in.
Type "fastboot devices" (without quotes)
If a random jumble of numbers appears, then your tablet was detected. If it wasn't, you need to install the proper driver, such as the Universal Naked Driver
If it detects it, then you're good.
Download the factory Nexus 7 image I linked in the post above (Here it is in case you're lazy)
Extract the contents and then extract the second zip file within the zip file to the location of ADB you installed earlier.
Type "fastboot flash boot boot.img" (without quotes)
Type "fastboot flash bootloader bootloader.img" (without quotes)
Type "fastboot flash recovery recovery.img" (without quotes)
Type "fastboot flash system system.img" (without quotes) and it will send the system image to your tablet.
Once it's done, use the volume rocker to select reboot and press the power button to reboot the tablet and see if it boots. Give it a few minutes and it should boot.
If it doesn't boot, we can come back to that and try flashing everything else.
