Post A Pic Of Your Pc Here :)
Motorcharge
Well-Known Member
Good enough I wouldn't consider replacing it with another non-liquid cooler. Quiet too. Haven't tried overclocking with it though. My only complaint about it is they edit the light on it in the press shots. You can't even tell it's there unless you look for it, it barely lights up. It came with my CPU though and I knew when I bought it I was planning on doing a liquid cooling setup at some point regardless. For a stock cooler though it's pretty awesome.
mistersprinkles
Cable mess under the desk detracts from overall awesomeness. I need to fix that.
There's a cable mess inside the tower too. I haven't bothered to do fancy cable management since there is no case window.
Machine has a 1080 and a GQ650 (EVGA) PSU now. This photo was with a 980 and a CX500.
beers
Moderator
Here's one from my file server, five years ago. Cable management fail :p
Was some garbage like Athlon 64 X2 4400+, 2 GB RAM, 7x 750 GB HDD on like Ubuntu 9 that ran on a 4GB CF card. Fun times, junk seems to have changed a lot since then.
Laquer Head
Well-Known Member
Damnnnn check out those blue cable sleeves though!!!
Intel_man
Lol a Compaq keyboard.
For a second, I thought you had the LS50 monitors... then I realized they're just X300A.
mistersprinkles
Yes, they are the lowly X300A. I was foolish enough to put these on a desk. I would never dessecrate LS50s like that. And no, it's not a Compaq keyboard it's a Corsair K70 RGB with brown switches.
mistersprinkles
That comment was to @beers pic. Hence why it was above your quote.
Are you a KEF fan?
My bad my bad on the keybo.
These X300A sound spektackular hooked up in a proper room with proper positioning on good stands but I lack such an environment.
Any tips for taming the cable disaster I have here?
Cant stick anything to the back of the desk as my LED strip is there...
Calin
Well-Known Member
Haven't posted in a while. Upgraded to SLI, changed to PETG tubing and added more storage. Yeah, it's a bit dusty but I will clean it soon.
Calin
Well-Known Member
That's a great looking and spec'd rig. With those specs you won't have to upgrade for at least a couple years!
Thanks man.
By the way, this is my secondary rig I built a couple of months ago to use if something goes bad in my main one. Ignore that HDD I painted when I was 12, I changed it with a SSD.
Edit: New case coming soon for it
Geoff
Thanks man.
What are the specs of it?
Calin
Well-Known Member
Got the new case for the secondary rig today but it turns out the PSU is bad. It will stay like this until I get money for a new PSU. That dusty fan will be going out too.
