personally id get a dif mobo then asrock, id get this mobo if ur just lookin to use most of ur old stuff, but u will have to upgrade to a pci e card, can get a cheap one from newegg or ebay but this way u know its a descent board brand wise, both ram support, but only 533 ddr2 better than ddr either way though, and it has pci so ud only need to upgrade ram down the road...
mobo
http://www.newegg.com/Product/Product.aspx?Item=N82E16813127017
One supports a quad core C2d and the dual VSTA supports a dual core.. And i'm gonna be the voice of objectivity in this. Cause i say go for it.I was even thinking of getting that board after i noticed your first post on this a couple weeks back. Anandtech has a review of ddr2 vs ddr1 using this board.
http://www.anandtech.com/mb/showdoc.aspx?i=2810
I don't have alot of money to spend on my computer also.. So i consider this board great.![]()
Right, I've done some researching!
Which of these would be better?
To get the ASRock 775DUAL-VISTA and an E6300 (DDR, DDR2 - up to 2GB, AGP x8, PCI-e x4?
Or
To get the ASRock 939DUAL and an Athlon x2 4200 (DDR, up to 4GB, AGP x8m PCI-e x 16?)
Which of those?
Thanks.
I think the socket 939 would be the well better option!
Don't you think, up to 4GB of RAM, PCI-e x16 or AGP and an AMD dual Core?![]()
Nope, I hearb bad reviews on the 939 board and didn't want to try and send it back and be stuck with a 939 CPU to send back.
I think the ASRock 775DUAL-VISTA is looking like a good option at the moment, with an E6300.
