Opinions Please
ok
e6300- £111.45
1 gb (2 x 512mb) Kingston Value Ram 533 mhz ddr2- £49.99
Gigabyte GA-965G-DS3 Mobo- £78.12
Point of View 7600 GT 256mb GDDR3 pci-e -£70.05
Western Digital 200GB SATA 7200 rpm HDD- £41.25
£350.86 Thats a good setup but you'd need a bit more in order to top it off. Like with a case and stuff.
ok
e6300- £111.45
Why a bit more? You hit the 350 mark, and he already has a sweet case. :)
ok
e6300- £111.45
I already have a HDD, so I don't need one of them.
7600 GT, is it any good, is it better than the card I have at the moment?
Lol, Thanks :D
EDIT: Hows this for a MOBO?
http://www.ebuyer.com/customer/prod...hvd19wcm9kdWN0X292ZXJ2aWV3&product_uid=109643
hey mate that looks a good build...and only for Total: £304.....you could overclock the e6300 then im sure that system would be cool.
you could re-use your cd drives you have and your case....dunnu about the Psu though.
Yeah, It's a good price...
Yeah, They read up well, I'll look into that MOBO too, Thanks.
The PSU, I HOPE it'll work as I just bought it and my parents won't be best pleased.
Mate where do you see the e6300 for £100?
Thats a great deal :) ....if i did have one i would overclock it.
I just looked the 7600GT up and it's worse than the card I have now:
http://www.gpureview.com/show_cards.php?card1=385&card2=58
EDIT:
I've come up with this build what do you think?
Abit GD8 Pro SKT775 - £46
Core 2 Duo E6300 - £100
Sapphire X1950Pro 256MB 256bit GDDR3 - £108.95
OCZ 512MB DDR2 533MHz - £25
Total: £304
I think it's excellent :D
Hey Koronowski, I don't think the MOBO you've chosen here supports core2duo. This is MOBO I'm planning on getting
http://www.microdirect.co.uk/(16724)Abit-Fatality-FPIN9SLi-Motherboard-LGA775.aspx
It supports the RAM you've chosen above and its a MOBO that can support core2quad if ever you decide to upgrade in the future and it supports SLI.
Here is the manufacturer's specification link:http://www.abit.com.tw/page/en/moth...pecifications&fSEARCHTEXT=Fatal1ty FP-IN9 SLI
Well, if you're going to get a new CPU/Mobo, definitely go for the e6300, but the whole idea of upgrading atm might not be a good idea IMHO.
Why wouldn't you upgrade at the moment?
Thanks for the link, I'll check it out.
Are there any less expensive MOBOs that support Core 2 and have 3 or more RAM slots?
I've come up with this list, What do you think?
Abit Fatality FP-IN9-SLi Motherboard - £71.68
Core 2 Duo E6300 - £111
Total: £341.63
Is there another GPU that I could get that is cheaper and is as good or better than the one I have now?
The OCZ operates at at least 2.1v methinks, whereas the DS3 has to be able to get the RAM to 1.8v
EDIT: Ignore that, the 533 does operate at 1.8v...
