Kornowski
Is your PSU not modular? It does look way neater, I hate wiring with PSU's that aren't modular.
Nope, it isn't a modular PSU
Nope, it isn't a modular PSUThe next PSU I get will be a modular one though, probably a Corsair.
I just ordered one, I would have ordered some cathodes and some of the uv-reactive stuff you have but, it's going in a P180.
lol, Thanks Shane
Yeah, I felt like the fan duct would help to puch it more into the case... It did aswell
Erm, I don't really know, I know what may next upgrade will be, another GB of RAM, then a new PSU and GPU, but the PSU and GPU won't be for a while yet.
Maybe some cathodes, I don't know if UV cathodes are cool though, I've never really seen them, apparently, the cable sleeving is UV reactive, do the UV cathodes give off a glow, like normal cathodes?
P.S. Did you notice I sleeved my Keyboard wire too, Pink![]()
if you're gonna put lights in it you should of bought the p180 with the side window.
Yeah the UV is basically a blacklight, you need a new PSU, I remember you asking about your Earthwatts 380W, is that the one you have now?
So it wouldn't light the case up like a normal cathode?
Yup, I have the 380watt Antec Earthwatts, it does really well, runs my system without a hitch, with two 12v rails with 17A on each, not bad.
lol, Thanks Shane
Got a duct for my 80mm fan on the front, helps it flow the air into the case, dropped my CPU temp by 1c,
Another shot of the cables I sleeved
A shot from the back of my PC
Nice...whats that mouse you have?
Looks like a Dell one.
Looked on the Dell site, couldn't find anything.
