How clean is your interior?
vroom_skies
It used to be a lot better than this, but then i started working on the insides quite often. So it wasn't worth it to redo after every time.
Bob
ThatGuy16
my tray isn't removable but i can take the side off behind the tray and run wires. What case do you have skidude?
patrickv
my PC is a low down dirty piece of sh*t, i clean it every saturday or 2 weeks but no matter how much i clean it somehow catches dust along in the week.
I never close my Pc it remains open all day:D:D
below is inside my Work DELL pc,
i will post my home pc later:)
twolves90
Mine is SO BAD..... But maybe the "busy" look is kinda nice? lol........
Oh well...... I can keep trying when I have some patience
thx for looking
EDIT: My temps do stay kinda low..... cpu at 34....gpu at 61.... actually, is this bad?
Bradan
I'm going to get some green 12" cathodes :D
So what did you do Brandon, cut holes in the MB tray, or simply run them behind it?
Rekon I could do it with mine? The only probleem is, I can't seem to be able to remove the other side pannel, could it be rivited in? Think I should try running them behing my tray? (see pics)
needed to cut holes, thats what the bulk of the work was
Looks realy good.
Here is my last attempt at moving cables around. Your thoughts??
Working around the top fan is annoying, i want as much cool air to get to the ram slots as possible.
g/l
good luck
Your thoughts?
Bradan your case looks so nice now, im envious
thanks!:)
ya i see what you mean with the fan, it isnt as important, flow in your case is for exausting heat from the case. you could have a 60mm blowing on the ram doing more than the 120 end up doing.
generallly, just pair wires, bundle and zip tie exess wire neatly.
easiest way is to take all the wires out that you can, route the more perminent wires, then add in wires one at a time using the best route for each wire.
Kornowski
I can't seem to find anywhere to put my cables out of the way, it sucks!
When I get the cathodes, I'm going to mount the rocker switch on the front of the case.
Bradan
ewww :p
jk,
u have nearly the same setup as me as far as space and cables, shouldnt be too hard
does the foam do anything?
ThatGuy16
Better airflow= a cooler case. Just depends on how messy it is as to if it would actually help, other than that its just for looks.
Kornowski
ewww
jk,
lol :p
I don't have a modular PSU, do you?
I guess when I get the cathodes and the other stuff, I'll give it right old sorting and hopefully it'll look Ok then.
Yeah, the foams good, it absorbs some of the sound from the fans, I've noticed it to be not as lound, and, of course it looks better :D
ThatGuy16
Heh, ever wondered how many wires and cables i got im my case? if you think of a better way of organizing, you get a cookie :D
So between the controller, switches, and fans...i think i could throw a rope to china :D
Kornowski
There are so many, I didn't think it was possible :p
Just got a HDD adaptor to put it in the spare CD drive, fits in great, keeps it out the way!
Also, some 12" blue cathodes, they look excellent!
Pictures to come later! :D:D:D
Oh, and I re-applied the AS5 and I'm getting 34c already, so they should drop some more too :D
