I'm going to get some green 12" cathodes
So what did you do Brandon, cut holes in the MB tray, or simply run them behind it?
Rekon I could do it with mine? The only probleem is, I can't seem to be able to remove the other side pannel, could it be rivited in? Think I should try running them behing my tray? (see pics)
Looks realy good.
Here is my last attempt at moving cables around. Your thoughts??
Working around the top fan is annoying, i want as much cool air to get to the ram slots as possible.
g/l
good luck
Your thoughts?
Bradan your case looks so nice now, im envious
I can't seem to find anywhere to put my cables out of the way, it sucks!
When I get the cathodes, I'm going to mount the rocker switch on the front of the case.
Better airflow= a cooler case. Just depends on how messy it is as to if it would actually help, other than that its just for looks.
well if thats the case, id say 99% of the efforts made in this thread were made in vain
ewww
jk,
u have nearly the same setup as me as far as space and cables, shouldnt be too hard
does the foam do anything?
I wouldn't even know where to start on that!
Do you need all of them though?
