Buzz1927 said:Well i'm writing this in safe mode.
yes it does, select the option safe mode with networking. im with cable broadband though, dont know if it makes a difference thoughevilxp2800 said:Well you cant Be because Windows XP Dont Support Internet In Safe Mode ..i have Treid on my Computer and its dont work
LOL, 2 people have proven you wrong, i could take a screenshot if ya wantevilxp2800 said:Wateva ....Noob ...
Buzz1927 said:Its ok to delete them.
Buzz1927 said:Someone on another forum had the same problem as you. This was the advice given.
1. Exit MSN Messenger completely.
2. Click Start, the Run, type regedit and click OK.
3. Navigate to:
MyComputer\HKEY_CURRENT_USER\Software\Microsoft\MSNMessenger
4. Click (don't double-click) the MSNMessenger key. It should simply highlight the name.
5. Go to the Edit menu and click Delete. Click Yes to confirm the operation.
6. Install MSN Messenger 7.x or 6 and sign in!
7. Done
elmarcorulz said:LOL, 2 people have proven you wrong, i could take a screenshot if ya want
3. Navigate to:
7. Done
Buzz1927 said:Weird. See what you get in HKEY_LOCAL_MACHINE\software.
Buzz1927 said:Well, the instructions from the other forum said MSNmessenger. Try that first and see if it works, if not you could try the others.
Buzz1927 said:Might be because you couldn't do it in CURRENT_USER. I'll see if I can find any other ideas.
Buzz1927 said:I don't know if that'd work, it says "for xp". Couldn't hurt to try, or maybe you can find an alternative here.
