tylerjrb
restart your pc and hit the given command to enter bios on the start screen which is like f11 or delete.
If you have the maximus VII hero it will load up like this: http://www.illgaming.in/wp-content/uploads/2014/11/hero-7.jpg Might need to click onto advanced tab.
as you can see on the first tab it says memory frequency about 1/2 3/4 way down the page. Click that and it will bring up a list of frequencies. Click on the frequency that is the same as your stock RAM which is 2166mhz i beleive. Scroll down it should say DRAM voltage or something like that. Ensure that this is set to the same voltage as it says on the specifications on the RAM which for the g-skill on the first page of the thread is 1.6v. simply click and type 1.6 and hit enter. Restart pc and load bios it will then say the current RAM speed which should be 2166mhz. It will make a more noticable difference on desktop in opening apps etc over 1333mhz as it will be much faster. It will give you a few frames more on games however.
im pretty sure asus do some good videos on cpu overclocking and RAM overclocking. alternatively on this page in the bios you can set it to XMP as ninja has stated and it will automatically set to the given frequency. http://www.kitguru.net/wp-content/uploads/2014/07/tweaker-1.jpg
Similarly to the cpu, you have the h100i correct? You can push the cpu pretty far over stock.
