Project :: Dark_Water
ALPHA COOLING PUMP & RADIATOR I SEE :D:D:D
How come your not gonna watercool the Northbridge chipset?
Anyway good luck with your mission and hope it goes well :P
It's taking so long that by the time he's completely finished with everything, his computer is going to be out-dated......
If I were you, I'd put in a 8800GTS/X before your finish and 'lock' things up....
So it's nearly done? It's been fun watching your progress over the year Mankz. Hope the computer goes well for you. :)
i would put an 8800 of some sort in there, but only if i got sponsored with one.!
Im not really all that fussed if it is 'out-dated' becuase, it'll still do what i want. I only really play things like BF2 and some CS:S for a few weeks during the holidays, at fairly low 19-21" reselutions ect.
the spec. is as follows....::
Asus A8N-Sli Deluxe
AMD Opteron 146
1Gb BH-5
ATi X1800 XT
160GB SATA-II
DVD-RW
BIX2
DDC w. Top
TDX A64
EK FC18/19
Repack res.
all i need to do is basically paint the front panel, and finish sanding it, paint the door lock, and also the feet, then its done.
i think.
looks ok. I mean, sure, there i a lot of work in it,.. But i dont really find it too look really special or something like that. =o
sorry, not at the moment...
im having massive trouble with the 12v connections, hence no pump and no boot ect.
im seriously considering getting a new PSU, and sticking this one in the trash:mad:
you wouldn't want it....
I reccon its pumping out about 100w on a good day....
so im looking for something 700w +
:/ Im running that same pump and it runs fine with my PSU!?
Ive had it for just over a year now and touch wood I have had no prob.
Though I changed the liquid not to long ago to give the pipes and pump a good clean.
