Heh, welcome to the internets.
Here's what I'd suggest, so far:
--I'm having trouble locating a motherboard, and the CPU I think would work best isn't on newegg yet, but this is shaping up to be an awesome build. I'm trying to find a motherboard that can handle-and overclock- two of these:
http://ark.intel.com/Product.aspx?id=47926
Two of them makes twelve cores, twenty-four threads, and only 60W each, which means they should have some awesome OC potential.
--For the GPU, I'm thinking two Radeon HD5970's in crossfire. The GTX 480 is good too but 1- I don't know if the chipset supports SLI and 2- they use a crap-load of power and have been known to kill the i7 980x in quadfire. You also get eyefinity with the 5970. Two of this one would be fine:
http://www.newegg.com/Product/Product.aspx?Item=N82E16814102887
--Bomber was nice enough to point out the right RAM and PSU...that'd be these:
PSU-
http://www.newegg.com/Product/Product.aspx?Item=N82E16817703020
RAM-
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231335 (Two of these kits would work fine. Most dual-socket 1366 boards will support either 12 or 18 DIMMs)
--For the case, I was thinking a mountain-mods ascension. (even before bomber mentioned them, haha) Read the review, or at least the last 2 pages, and tell me what you think (They come in black, btw)
http://www.overclock3d.net/reviews/cases_cooling/mountain_mods_ascension_pc_case/1
Here's the thing to build it with..you get to pick your parts
http://www.mountainmods.com/ascension-cyo-choose-your-own-p-483.html
If you get it, make sure to grab the E-ATX motherboard tray.
These add-ons would all be good/useful/fun..all just ideas:
Fan controller-
http://www.newegg.com/Product/Product.aspx?Item=N82E16811992004 (touch screen, like you asked. You may need a second controller though.)
Drawer(s)-
http://www.newegg.com/Product/Product.aspx?Item=N82E16811998076
Card reader-
http://www.newegg.com/Product/Product.aspx?Item=N82E16820223103
Cup holder/lighter/12v socket(lol)-
http://www.xoxide.com/xray1.html
--These drives should work well:
OS-
http://www.newegg.com/Product/Product.aspx?Item=N82E16820227469 (60GB version of what Bomber posted)
Storage- 2x
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136456 (same as before...caviar black 2TB in RAID1)
Blu-Ray/DVD- (same as before)
http://www.newegg.com/Product/Product.aspx?Item=N82E16827106335
http://www.newegg.com/Product/Product.aspx?Item=N82E16827136181 (really isn't necessary, but BR is awesome...)
--Monitors again-
http://www.newegg.com/Product/Product.aspx?Item=N82E16824236047
I think you'll need one of these adapters, or one like it:
http://accessories.us.dell.com/sna/...etail.aspx?c=us&l=en&s=dhs&cs=19&sku=330-5521
--OS- one of these (I'd suggest ultimate...it's not much more than pro)
Win7 pro-
http://www.newegg.com/Product/Product.aspx?Item=N82E16832116717
OEM-
http://www.newegg.com/Product/Product.aspx?Item=N82E16832116758
Win7 ultimate-
http://www.newegg.com/Product/Product.aspx?Item=N82E16832116718
OEM-
http://www.newegg.com/Product/Product.aspx?Item=N82E16832116762
What this leaves-
Mobo- no idea on this one. I'm sure there's one that will work but I have no idea what it is. This would work well, but I don't know if it can overclock:
http://www.newegg.com/Product/Product.aspx?Item=N82E16813182174
Fans- The case doesn't come with any. I'd guess you want red LED fans? Anyone want to chime in here? I'd assume Coolermaster R4's would be ok...?
http://www.newegg.com/Product/Produ...&cm_re=coolermaster_R4-_-35-103-063-_-Product
CCFL's(internal lights)- Again, no idea which ones are best...help?
Cooling- The CPU's are 60W, which is really low for a CPU like this. It shouldn't take a whole lot to cool them, which means that a couple of good air coolers would work quite well. Water cooling would, obviously, be more effective, but it seems like a WC system like that could be pretty complex. I'm no expert on that though...can someone else chime in?
CPU- I know the right one to use, but I can't find any known-to-me stores that have it. Is Provantage ok?
http://www.provantage.com/intel-bx80614l5640~7ITEP36T.htm
Sound card...? You might want one but I'm clueless. The only ones I've used are for recording...
So far this is looking to be a $5000+ rig, but it's fast enough that you could use virtual machines to run 3-4 dedicated game servers at the same time on one screen, while
playing a game at above 1080p on another screen, and rendering a huge clip on the 3rd screen. It's an absolute monster. It hasn't been too long ago that this would nearly be considered a supercomputer.
