joh06937
not yet, is freezing ok, nothing bad on the video card??
it was most likely just instability. just means a tweaking of the settings is required.
ok, jacked it up to 1200, how long should i run FURMARK for?
it keeps freezing during boot up?
Well it did, but i allowed windows to fix itself and it removed those settings, back in buisness.
thats what im thinking XD. Its working now so i think im going to wait till later. ffxiv is better with a working video card then without![]()
alright dude thanks alot for the help! one last thing, there shouldnt be any resulting problems from these test later on down the road right?
no problem. i have nothing better to do
you should be fine. the instability-caused freezing shouldn't harm the gpu at all.
so I'm wondering, do you think the fail in overclocking is because my 750w power supply? I notice the 5970 requires at least a 650w supply.
It is a possibility. What brand/model of power supply is it?
