I didn't see any performance gain when @ 2.4Ghz compared to the 1.86Ghz at stock.
About my Northbridge, is it being warm (not burning my hand) Ok? Is there a way I can check the temps of it?
Ok, It's hot / warm, it doesn't burn me so I guess that's Ok.
How much hotter will it get if I add 0.1v to the MCH?
Is that all I should do, then put the FSB up some more?
Thanks![]()
Adding 0.1v to the MCH will increase heat little to none.
Ok Sure, Thanks a lot Rambo!
Howcome you've dropped yours from 3Ghz to 2.8Ghz?
Ah right, Yeah, It's better to have it stable than running slightly faster... Mine hasn't crashed since I got it, Don't know how long it's been, but I haven't had it OC'ed.
So I could test it with Orthos you mean, and if it passes stable, it could still restart some other time?
I may just shoot for 2.4Ghz or 2.6Ghz, I don't think I'd need / want to go any higher... I think I need to buy a new HSF before I try it again, because I was idleing at about 38c.
Howcome my RAM is working fine when it's 0.1v under the recomended?
