just a noob
Well-Known Member
woot, looks like im either going to be buying 3 more 9800gt's or gs's, maybe even a couple of gx2's plus the 9800gt i have sitting on my desk right now
oh, and i found that 4 8800gs's bring in around 15k ppd
Just signed up.
Are you guys still doing this?
IN the configuration menu, what is the passkey field for?
Well, you're still getting points so I guess it's from the family comp. The PS3 will get a lot more points than the comp (I don't fold on my comp at all), unless you have a supported graphics card, and leaving it running 24 hours doesn't really use much electric. If your mum doesn't believe it, ask mep if you can lend his gadget!It's been awhile since I've gotten any folding done, and I feel kind of bad for not doing any. My desktop in my room isn't set up for folding at the moment, and I'd much like to upgrade it before I even try to fold on it. It has some serious heating issues...
the computer that my parents have, that use to be the family computer... I'm not sure if they still have the F&H thing running on there. I'm sure they didn't remove it, since they aren't all that computer smart... but I also can't remember if it's still folding while it's turned on.
I do have a PS3, but I haven't had that Folding lately, either. Ever since our move, things have kind of went... poof on a lot of things. Once I get back to my mom's I plan on just setting up the PS3 to Fold when I'm not playing games on it (Ex: playing on the Wii or 360)
The only problem so far is that my mom isn't happy with me keeping the computer on over night due to, "That's money, you know." Though... I doubt turning it off each night would really make much of a difference, would it?
i don't think so, i think someone figured that the energy it takes to get the hard drive platters spinning and for how long they are just spinning, it is about equal to how much it uses overnight, if you're really tight, i think you can make the program only have about a 25 percent load
You can just shutdown the computer and it will continute when you start it up again. However depending on the WU, some have a short deadline, so you may want to be careful of leaving it for too long.
As for the second thing, I have no idea.
I'm folding on my GTX 260 and have moved from 112th to 73rd! I'll keep going too as unlike my old GT this thing doesn't get to hot...![]()
Bizarrely the client fails self test due to an unstable machine
It's random, today it's gone through 3-4 WU's fine but some other days it may only do 1 or 2. I think it may be a 7 issue though, temps are never above 70 or so and the card does sit at stock.
