Project :: Dark_Water
Mankz_91
hello again, well sorta......
the reason i stopped doing this project, has been 'left by the road-side' i.e. i dumped her....:cool:
ive not done that much, as ive been trying to have as much fun as possible, but ive done a little bit over the last few days, which i'll post in a couple of minutes..:)
there should be lots of big/little updates over the next couple of weeks or so.......:D
AJ¬
Mankz_91
Update :: Ive done some CNC today...!
Designing it on MAC...
some other minions...
The Laser cutter...
6mm Acrylic before cutting
Cutting in da machine'!
finished product
nice and shiny :dremel:
and now back to 'me time'... Banana Nesquick....Jam on Toast....Midget Gems....and Futerama.....
Rambo
Nice to see your doing something with it now. :)
What is that peice of plastic you cut out, going to be used for? It looks a bit like a fan holder, but I'm not sure...
Mankz_91
they have decided not to slice me open in the end
i just have to 'rest' it for a week or so..... :duh: but being almost 15, im not going to listen to them :naughty:
Anywho....im hoping to get my orderes put in tommorow for a whole load of watercooling and general modding bits..... :clap:
I did some marking out on the Mobo plate for where im gonna cut it. This will be so i can easily tighten/loosed the hold down for the TDX...
And some other random photos of the hardware.... (I love that RAM!!!)
and now back to killing people on BF2 :p
Mankz_91
......Anyway, I was getting all the other 'bits' ordered when i sorta realised i can't afford half of it.... So now, there is no aquatube ect. but i still ordered the barbs, however, i think i forgot to order the 8/10mm tubing :wallbash: :wallbash: :wallbash: :wallbash: :wallbash: :wallbash: :wallbash: :wallbash:
So, if i have, i'll have to go back to using my 1/2" ID tubing.... anyway im gonna get some more spray paint and filler to use on the front drivebays.....
but yesterday....::
I wanted the front door to look plain, so i wanted to get rid of the holes that show the HDD and Power LEDs.. (these are gonna be hooked up the LED's on some vandal switches -|- the Power one will go on the power switch -|- the HDD activity will go on the LED on the CC on off Vandal.....)
Because there are no LED's, i started sanding off the small images, and will dremel out the rest of the raised holes this afternoon....
Mankz_91
first update of today....
i went out earlier and got my self some fairly cheap Bonbo / Car Body filler to use on the front bezels.....
I want the main front to look slightly plain, but flat and clean.... Im gopping to eventually get a small temp read-out to go next to the switches (which should be here tommorow morning......
This is my first experiance with filler, so i hope it looks good after some sanding.....
Mankz_91
well, my filler hasn't dried...... so when my mum and my brother are out tommorow i can start doing some proper sanding....
i started drawing the mounting holes for the pump... im gonna try and use some M4 screws and bolts....
and heres a general shot of the random room where im working...
my packages should be here tommorow aswell.....
Mankz_91
This morning, 3 of my 4 packages arrived.....
A load o' general Modding Stuff....
I was supprised how big this Heatsink was....
It didn't fit on becuase of my EK X18/19 so i cut down some of the smaller
fins...
i used some AS5 when mounting it instead of the funny stuff that came with it....
Mankz_91
Package 2....
im quiet annoyed because i didn't get my PSU silencer or my Molex extractors.... :sigh:
Package 3
when i opened the package, i found this...
but when i opened up the box i found this...
I like the look of the HDD silencer....
fit very nicely....
BUT... i ordered 2 right-angled barbs, 14 straight barbs, and some 'molex eyes'but only got one of ech of the barbs and non of the molex things....
so i hope they may come later today....
Rambo
Wow - it seems that if everyone just ignores this thread, you post lots of pictures and updates! :D
Very nice work Mankz!
P.S. Who takes the picture when you're playing BF2? :)
Archangel
you know whats the downside of this project tough... by the time its finished the pc in side will be outdated. ;)
anyway's.. looking good so far
Mankz_91
hush..........:D
im not fussed if the hardware is old...
i'll keep it for a while, get a mid range DX10 card and 2Gb of RAM eventually....
Im off to go sanding again now, then when my other package with the various cables and fans come, i can start putting it together....
Im gonna keep the inside of th case as it is for now, then may take it all out and get it painted at school....
@ Rambo...:: It was taken by my Brother....
